TVE - DirecTV and AT&T Spinoff
Hello - I read that AT&T has fully spun off DirecTV. Any subscribers here know if this will change the login and password process? Currently you login through AT&T.
I'm not a subscriber, but use my parent's credentials for TVE, so hoping there isn't a change!
It's the same folks, the same systems being used so this should not impact anyone's current credentials even with the corporate name change.
FYI: on the other hand, we had an issue 3 days ago and the fix included changing our login from an att.net email address to our email address (we kept the same password).
