Is anyone else having an error trying to watch TNT on TVE? Here is the error:
2019/11/05 15:26:12 [ERR] Could not start stream for TVE-Spectrum ch6036 TNTP: TVE: get: https://turnerlive.akamaized.net: 404 Not Found
I have Spectrum.
I have Spectrum.
Thanks for reporting this issue.
There's a fix in v2019.11.05.2336. To update, click-and-hold the Check for Update button on the DVR web UI.
Updated version works perfectly.
Thanks for such a great product!
Thanks, I missed AEW tonight because of this I'll update ASAP!
Is there a way to trigger auto updates on the DVR or maybe another way to get updates without having to check periodically or come to the forum?
Yes I am lazy and yes this is a first world problem but thanks in advance for your response!
The DVR will automatically check for stable updates/releases. Unfortunately, if you are using beta/pre-release versions, updates must be manually checked for.
(You can use a script, cronjob, systemd timer, atd, scheduled task, or whatever else your OS uses to facilitate regular background jobs to check for pre-release updates. Just send an HTTP PUT request to /updater/check/prerelease on your DVR server to initiate an update check.)
Thank you, thank you, thank you! I've been beating my head with this issue for a week.
PS. Thank you for such a great product!
I think the TNT error may be back; well at least for me. Here's the snippet from my log:
2019/11/13 15:32:27 [ERR] Could not start stream for TVE-DTV ch6035 TNT: TVE: get: https://turnerlive.akamaized.net/hls/live/572088-b/tnte/noslate/VIDEO_3_1928000.m3u8?hdntl=exp=1573705943~acl=%2Fhls%2Flive%2F*~hmac=3e527de60f651dd6fe1fc015fc42be6372fee9cf73d9ecbd4b14d8635443abf5: 404 Not Found
You have to click-and-hold the Check for Update button for the fix.
Thank you as always for your quick replies!
