TVE for appleTV?
How to add to AppleTV?
Did you enable it on your server?
Try restarting the Apple TV app: click TV/Home twice and swipe up.
yes, I enable on server and can see channels. But i don't see any of channels on apple TV app. I see OTA channels oks.
Go to the Settings tab and you can add to favorites. Or change the Guide from Favorites to All or HD.
IN ATV app shouldn't I have another source, I only see OTA source?
I have version 3.2.13 on ATV. I tried favorites, HD, All and don't see channels, only see OTA channels.
Is it connected to your DVR? Do you see a DVR tab with the IP of your PC?
If not, try going to Settings and click Connect to DVR > At Home and enter the IP.
yeah, i have DVR, it shows my passes.
Version 3.2.13 is incredibly out of date. You should have 3.2.25. Go to the app store and manually update the app.
thanks maddox. that was the problem. I tried to update but didn't think about going to app store to update.
Great!
