I’m having an issue with some TVE channels not connecting, network type error. This has happened before but solved with a server or app update. I had the same problem with android version but was solved with there latest update. Could this problem be solved with the next Apple TV update?
Search is your friend, Being discussed in a couple of other major threads.
