When attempting to play the NFL Network, via TVE using DirecTV credentials, playback never starts -- it just continually attempts to reconnect.
Running version 2022.09.14.2324.
Log snippet looks like this:
2022/10/03 11:08:35.628938 [TNR] Opened connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:35.673129 [HLS] Starting live stream for channel 6192 from 192.168.110.53 (bitrate=3200)
2022/10/03 11:08:36.188618 [HLS] ffmpeg: ch6192-dANY-ip192.168.110.53-remux: pipe:: could not find codec parameters
2022/10/03 11:08:36.259526 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.110.53: Stream stopped
2022/10/03 11:08:36.259526 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.110.53
2022/10/03 11:08:36.262145 [TNR] Closed connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:36.262765 [HLS] Probe failed for live stream after 589.6351ms and 0 bytes
2022/10/03 11:08:36.667791 [TNR] Opened connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:36.678296 [HLS] Starting live stream for channel 6192 from 192.168.110.53 (bitrate=3200)
2022/10/03 11:08:37.215778 [HLS] ffmpeg: ch6192-dANY-ip192.168.110.53-remux: pipe:: could not find codec parameters
2022/10/03 11:08:37.274117 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.110.53: Stream stopped
2022/10/03 11:08:37.274117 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.110.53
2022/10/03 11:08:37.278971 [TNR] Closed connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:37.280062 [HLS] Probe failed for live stream after 601.249ms and 0 bytes
2022/10/03 11:08:38.393391 [TNR] Opened connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:38.397457 [HLS] Starting live stream for channel 6192 from 192.168.110.53 (bitrate=3200)
2022/10/03 11:08:38.936477 [HLS] ffmpeg: ch6192-dANY-ip192.168.110.53-remux: pipe:: could not find codec parameters
2022/10/03 11:08:38.975932 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.110.53: Stream stopped
2022/10/03 11:08:38.975932 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.110.53
2022/10/03 11:08:38.980313 [TNR] Closed connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:38.980983 [HLS] Probe failed for live stream after 582.999ms and 0 bytes
2022/10/03 11:08:40.695894 [TNR] Opened connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:40.711610 [HLS] Starting live stream for channel 6192 from 192.168.110.53 (bitrate=3200)
2022/10/03 11:08:41.468772 [HLS] ffmpeg: ch6192-dANY-ip192.168.110.53-remux: pipe:: could not find codec parameters
2022/10/03 11:08:41.621185 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.110.53: Stream stopped
2022/10/03 11:08:41.621694 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.110.53
2022/10/03 11:08:41.627081 [TNR] Closed connection to TVE-DTV for ch6192 NFL
2022/10/03 11:08:41.627763 [HLS] Probe failed for live stream after 916.1529ms and 0 bytes
