Trying to watch TVE channels and on several channels CNN and MSNBC, it will play and then stop. I see the following in the logs
Starting transcoder for channel 6050 from 192.168.50.14 (encoder=remux, resolution=, deinterlacer=, bitrate=4200)
2021/03/31 17:15:49.733922 [HLS] Probe failed for live stream after 10.0641873s and 0 bytes
2021/03/31 17:15:55.632726 [HLS] Couldn't generate stream playlist for ch6050-dANY-ip192.168.50.14: Timeout waiting for session to start after 8s
2021/03/31 17:15:55.632726 [HLS] Stopping transcoder session ch6050-dANY-ip192.168.50.14 (out: 0s, finished: false)
2021/03/31 17:15:55.633113 [HLS] ffmpeg: ch6050-dANY-ip192.168.50.14-remux: pipe:: could not find codec parameters
2021/03/31 17:15:55.634113 [TNR] Closed connection to TVE-frontier_auth-gateway_net for ch6050 MSNBC
Logs have been submitted as 963cc2bf-df43-41ac-9991-0d21ca3f1812 .
