Here's a chunk of the Channels log.
2021/04/11 14:00:00.597653 [TNR] Opened connection to TVE-Spectrum for ch6104 HGTV
2021/04/11 14:00:00.684733 [HLS] Starting transcoder for channel 6104 from 172.16.1.5 (encoder=remux, resolution=, deinterlacer=, bitrate=5665)
2021/04/11 14:00:01.569612 [HLS] Probed live stream in 883.593323ms: h264 1920x1080 progressive 5428193bps
2021/04/11 14:00:01.649087 [HLS] Session ch6104-dANY-ip172.16.1.5 started in 2.400012431s
2021/04/11 14:25:50.182972 [HLS] ffmpeg: ch6104-dANY-ip172.16.1.5-remux: [mpegts @ 0x249b8b0] DTS 135249112 < 140258723 out of order
2021/04/11 14:25:50.183075 [HLS] ffmpeg: ch6104-dANY-ip172.16.1.5-remux: [hls @ 0x24a2f50] Non-monotonous DTS in output stream 0:0; previous: 140258723, current: 140257317; changing to 140258724. This may result in incorrect timestamps in the output file.
2021/04/11 14:27:09.920621 [ERR] Error during stream TVE-Spectrum ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/auso/slices/a00/e6cf0c55dac249f0a0f72e7c72e6f6cb/a007a30f640a46f98b28903ff00d3b07/F0000010A.ts?pbs=d0df8d4331624fbe8ff9ee8947396480&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&cloud=aws&si=1: Get "https://x-default-stgec.uplynk.com/auso/slices/a00/e6cf0c55dac249f0a0f72e7c72e6f6cb/a007a30f640a46f98b28903ff00d3b07/F0000010A.ts?pbs=d0df8d4331624fbe8ff9ee8947396480&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&cloud=aws&si=1": context canceled
2021/04/11 14:27:09.959589 [TNR] Closed connection to TVE-Spectrum for ch6104 HGTV
2021/04/11 14:27:10.269334 [HLS] Couldn't generate stream playlist for ch6104-dANY-ip172.16.1.5: Stream stopped
2021/04/11 14:27:10.271707 [HLS] Stopping transcoder session ch6104-dANY-ip172.16.1.5
2021/04/11 14:27:14.060817 [TVE] stream timestamps: hgtv: start_at=2021-04-11T14:26:12-10:00 current_at=2021-04-11T14:26:41-10:00 end_at=2021-04-11T14:26:42-10:00
2021/04/11 14:27:14.061112 [TNR] Opened connection to TVE-Spectrum for ch6104 HGTV
2021/04/11 14:27:14.100322 [HLS] Starting transcoder for channel 6104 from 172.16.1.5 (encoder=remux, resolution=, deinterlacer=, bitrate=5658)
2021/04/11 14:27:15.024672 [HLS] Probed live stream in 923.650386ms: h264 1920x1080 progressive 1654154bps
2021/04/11 14:27:18.239828 [HLS] ffmpeg: ch6104-dANY-ip172.16.1.5-remux: [mpegts @ 0x14108b0] DTS 130474 < 140666525 out of order
2021/04/11 14:27:18.255327 [HLS] Session ch6104-dANY-ip172.16.1.5 started in 7.131563907s
2021/04/11 14:27:18.296411 [HLS] Session ch6104-dANY-ip172.16.1.5 started in 7.172647645s
2021/04/11 14:42:20.281996 [HLS] Couldn't generate stream playlist for ch6104-dANY-ip172.16.1.5: Playlist has not been updated in 20.139016144s
2021/04/11 14:42:20.282121 [HLS] Stopping transcoder session ch6104-dANY-ip172.16.1.5 (out: 14m49.151722s, finished: false)
2021/04/11 14:42:20.307891 [TNR] Closed connection to TVE-Spectrum for ch6104 HGTV
2021/04/11 14:42:26.045999 [TVE] stream timestamps: hgtv: start_at=2021-04-11T14:41:21-10:00 current_at=2021-04-11T14:41:48-10:00 end_at=2021-04-11T14:41:52-10:00
2021/04/11 14:42:26.046249 [TNR] Opened connection to TVE-Spectrum for ch6104 HGTV
2021/04/11 14:42:26.080280 [HLS] Starting transcoder for channel 6104 from 172.16.1.5 (encoder=remux, resolution=, deinterlacer=, bitrate=5658)
2021/04/11 14:42:27.249531 [HLS] Probed live stream in 1.168755044s: h264 1920x1080 progressive 5504000bps
2021/04/11 14:42:27.308666 [HLS] Session ch6104-dANY-ip172.16.1.5 started in 6.466354075s
2021/04/11 15:03:34.152188 [HLS] Stopping inactive session ch6104-dANY-ip172.16.1.5
Can't see how this can be a NextPVR problem. Channels very clearly loses the connection then re-establishes it. And the time that takes is enough that NextPVR assumes the channel has died. One of the questions is whether if I was using Channels to save the recording if I would get a recording that has periodic 10 second gaps in it. But that doesn't get around the actual problem, it just gives me a recording broken in a different way.
