TVE Recording shows Interrupted and logs error Cancelling stream after 2m0s read timeout
How much of this Season Finale did it miss recording?
2020/11/24 18:12:22.569309 [TNR] Cancelling stream TVE-Comcast_SSO ch6070 after 2m0s read timeout
Re-recording it from my HDHR Prime to see what the TVE recording missed and probably delete that TVE recording.
2020/11/24 17:59:00.010637 [DVR] Starting job 1606269540-32 Primal Survivor on ch=[6070]
2020/11/24 17:59:01.569919 [TVE] stream timestamps: ngc: start_at=2020-11-24T17:58:01-08:00 current_at=2020-11-24T17:58:22-08:00 end_at=2020-11-24T17:58:30-08:00
2020/11/24 17:59:01.570013 [TNR] Opened connection to TVE-Comcast_SSO for ch6070 NGC
2020/11/24 17:59:01.570388 [DVR] Recording for job 1606269540-32 from TVE-Comcast_SSO ch6070 into "TV/Primal Survivor/Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg" for 1h5m59.989119627s
2020/11/24 17:59:01.741315 [IDX] Generating video index for job 1606269540-32
2020/11/24 18:12:22.620484 [MTS] Statistics for "TV/Primal Survivor/Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=688.391644
2020/11/24 18:12:22.631309 [TNR] Closed connection to TVE-Comcast_SSO for ch6070 NGC
2020/11/24 18:12:22.632943 [DVR] Job 1606269540-32 Primal Survivor ended prematurely: 52m37.367074704s
2020/11/24 18:12:22.693505 [DVR] Starting job 1606269540-32 Primal Survivor on ch=[6070]
2020/11/24 18:12:24.132153 [TVE] stream timestamps: ngc: start_at=2020-11-24T18:11:24-08:00 current_at=2020-11-24T18:11:44-08:00 end_at=2020-11-24T18:11:52-08:00
2020/11/24 18:12:24.132268 [TNR] Opened connection to TVE-Comcast_SSO for ch6070 NGC
2020/11/24 18:12:24.132397 [DVR] Recording for job 1606269540-32 from TVE-Comcast_SSO ch6070 into "TV/Primal Survivor/Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg" for 52m37.306308714s
2020/11/24 19:05:01.511181 [MTS] Statistics for "TV/Primal Survivor/Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=33 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=3972.700222
2020/11/24 19:05:01.512307 [DVR] Finished job 1606269540-32 Primal Survivor
2020/11/24 19:05:01.742099 [DVR] Processing file-1803: TV/Primal Survivor/Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg
2020/11/24 19:05:03.220250 [IDX] Generating video index for file-1803: Primal Survivor S05E04 Masters of Fire 2020-11-24-1759.mpg
2020/11/24 19:06:04.817823 [IDX] Finished video index generation for file-1803 in 61s
Well, looking at the logs you posted, it looks like you got 10 minutes. It started at 6. Then it was cancelled at 6:12 after 2 minutes with no data being received. Take those two minutes away, and you get 6:10 as the time when you stopped actually receiving data for the stream.
Edit: I see that the stream resurrected itself. So, if it ended at 7:05 as the logs indicate—and without further issue— then your recording was only missing the 2 minutes from 6:10–6:12. So, 63 minutes, roughly.
True by the log data. ONLY missing 2 minutes is 2 minutes too much.
I'm re-recording it from my Prime and will see what was actually missed. If it was adverts (doubt it), so what.
The more I record from TVE, the less I want to rely on it while I still have my HDHR Prime.
Will probably make TVE priority for Live viewing and prioritize the PRIME for recording.
Need diagnostics or the debug recording log to see what caused the disconnect
Alreadt deleted the recording.
Looking at the timestamps in my video editor and comparing it with the good recording made later from cable using my Prime, I found it was missing 114 seconds. Last 29 seconds of the first show segment and first 85 seconds of the first commercial segment. Hence I deleted it and kept the good cable recording.
