TVE seems weird
Is anyone having issues with TVE through FIOS. I can't get it working anywhere on websites or channels.
If you can't get it to work even from the websites directly, you must be having network issues on your side, or your FiOS credentials are not correct.
Any specific channels? I can try to see whether this is a general problem or just on your side.
What error are you getting on the websites?
Golf Channel, CNN
I'm able to watch both TVE channels live in Channels DVR using my DirecTV credentials.
So there are no issues with TVE and, unfortunately, the problem is on your side.
No issue with FiOS TVE here on CNN.
2023/04/06 12:20:59.432007 [TNR] Opened connection to TVE-Verizon for ch6030 CNN
2023/04/06 12:20:59.432913 [HLS] Starting live stream for channel 6030 from [...] (bitrate=4549)
2023/04/06 12:21:00.491181 [HLS] Probed live stream in 1.057814305s: h264 1280x720 progressive 3884584bps
2023/04/06 12:21:08.705016 [HLS] Stopping transcoder session ch6030-dANY-204996f90e55 (out: 17.922433s, finished: false)
2023/04/06 12:21:08.710863 [TNR] Closed connection to TVE-Verizon for ch6030 CNN
2023/04/06 12:21:08.710912 [SNR] Buffer statistics for ch6030 CNN: buf=0% drop=0%
If you can't get it to work on the website then it's nothing to do with Channels DVR.
Agreed.
@mstras what happens when you try on the website? How far do you get with your authentication?
What error message do you get?
