I've tried re-scanning multiple times and even deleted and re-added the Spectrum TVE source. Same. It authorizes only the local ABC choices and not CBS or Fox.
In the Web Admin under Settings -> Advanced in the Experimental section on the bottom right did you try to toggle off and back on Local Networks via TV Everywhere?
That is typically the first thing to test when trying to get TVE for local channels fixed.
Thanks! That worked partially. I now have my Fox affil but CBS still won't authorize.
Is there is anything else I should try for local CBS auth on Spectrum?
