TVE Stream Commercials Running into Programming
FWIW I have reached out to Channels Support twice on this issue but have not heard a response (on April 3rd, 2024 and again on May 29th, 2024).
Over the past couple of months or so the TVE stream for Jeopardy which airs on ABC Chicago (WLS) has commercials running into the actual programming. Trying to narrow down if it is the TVE stream that is issue or something with Channels. Below is the relevant log from a recording that exhibited this behavior:
2024/04/02 16:00:02.035026 [DVR] Indexed 1968 airings into XMLTV-SamsungTVPlus (334 channels over 15h0m0s) + 675 skipped [2s index]
2024/04/02 16:00:02.073783 [DVR] pruned 1937 replaced airings in 21ms.
2024/04/02 16:00:03.348495 [DVR] Waiting 23h29m56.651505115s until next job 1712176200-2 Jeopardy!
2024/04/02 16:03:22.922977 [TNR] Closed connection to TVE-Comcast_SSO for ch6001 WLS
2024/04/02 16:03:23.110458 [SNR] Buffer statistics for "TV/Jeopardy!/Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg": buf=0% drop=0%
2024/04/02 16:03:23.110524 [SNR] Streaming statistics for "TV/Jeopardy!/Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg": timeouts=0 segment_timeouts=0 playlist_timeouts=0
2024/04/02 16:03:23.164091 [MTS] Statistics for "TV/Jeopardy!/Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg": discontinuity_detected=27 transport_errors=0 saw_pcr=false saw_pmt=true highest_pts=2004.285767
2024/04/02 16:03:23.224513 [DVR] Finished job 1712089800-2 Jeopardy!
2024/04/02 16:03:23.382519 [DVR] Waiting 23h26m36.617481908s until next job 1712176200-2 Jeopardy!
2024/04/02 16:03:23.416530 [DVR] Processing file-3746: TV/Jeopardy!/Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg
2024/04/02 16:03:24.170808 [DVR] Running commercial detection on file 3746 (TV/Jeopardy!/Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg)
2024/04/02 16:11:14.680789 [DVR] Commercial detection for Jeopardy! S40E147 Jeopardy Invitational Tou 2024-04-02-1530.mpg finished with 4 markers in 7m50.549452437s (4 threads).
I also do have an OTA I was going to attempt. Is there a way to have it record both the TVE stream (6001) and OTA (7.1)? I setup a Pass for each and the OTA finds the Matches but doesn't actually record, guessing it determines it's duplicate?
First of all it's not clear what you mean by this.
The actual commercials run late and so you don't see part of the programming, or the markers Channels DVR puts in for the commercial segments are wrong?
Commercial detection will not be consistently 100% accurate. It's hit and miss.
Not with a pass on a single server.
Without a pass you can individually select the airings from the guide for recording.
Or setup another server so one server has the OTA source, another server has the TVE source.
Thanks for the quick reply. It isn't the commercial detection as I've turned it off. It's the actual stream itself. It will have commercials, go to an ABC logo with a message then go into the programming mid-way. This leads me to believe the TVE stream itself is the issue but wanted to verify. If it is I guess the next question is who would I even reach out to to complain..
Agree. You could verify by streaming it from their live website (where Channels DVR gets it from).
ABC. Good luck.
