TVE w/ YTTV, about 1/2 channels say not authorized
Setting up a new YTTV account with Channels.
Have deleted and rescanned source at least twice.
Most say "notAuthorized" some say, "mtvn mediaToken" or "adobe auth reg code: no login form found"
Rescanning individual channels manually just leads to 'not authorized'
I can view all the channels by loging into YTTV directly.
The channels that fail are the most important, ESPN,FS,Disney,CNN/TNT
More detail.
Win10 server
Was unable to connect source with YTTV google account directly, I had to create a new family account to get the source to connect.
Are you running any sort of ad blocker? I have YTTV and I get those channels without issue. I'm on Linux though so not sure if that is a factor. You can also try individually scanning the problem channels. Sometimes that will work as opposed to a mass scan
No ad blocker. I've tried to manually rescan individual channels, get the same 'not authorized' message.
Tried it on both Chrome and Edge
I use YTTV on Windows and have no issues either
have you verified that the account and password you are using for TVE with Youtube TV are working?
Just got it figured out w/ YTTV support chat, the sub. somehow got tied to a sub google account, and not the primary, so it was authorizing on the wrong account. Appears to be working now.
Weird that it authorized 62 channels w/o a valid subscription?
Glad you are OK now. Possibly those channels authorized long ago and when there cached credentials expired they would have wound up the same. I've experienced this with TVE and a different provider.
There are currently 68 "free" (FAST) channels (6700-6993) included in CDVR TVE that don't require authorization.
