Tried everything, updated to latest prerelease, restarted Channels DVR, rescan YTTV channels and most of the discovery owned networks do not come in. They work fine on the respective websites with YTTV login. On scans it shows “ Cable provider authentication failed”. Any ideas?
Just a quick thing to check and this depends on which OS you are using. Is chrome up to date? Also there is a manual update that needs to be done for nas where you click on support -> troubleshooting and see if there is a chrome update listed there as well.
Ive never seen that screen. Is that on the Server?
Thanks. That was it!
Nice!
Appreciate your help.
