So I’m pulling in schedules direct for a couple channels. Everything is available under channels except season and episode numbers?
Tvheadend is getting the right ep and season. So not sure why channels can’t see it from tvheadend???
Unclear what you're asking. Did you feed an m3u and xmltv into Channels from tvheadend? If so, can you provide an example <programme /> entry from the xmltv file that shows how the season/episode numbers are specified.
Strange, it has none of the ep or season numbers in the xmltv file?
