Tweak DVR/Recordings Tabs
I thought I would suggest a small change that I think would make the user experience of Channels DVR much better. I absolutely love Channels and this is more of an annoyance than anything but I've always been kind of confused by the separate Recordings and DVR in the apps. I think the user interface of these two tabs could be streamlined a bit, maybe they could be combined into one tab. I just know I often get confused by the two separate tabs.
The other aspect I would love to see is the search bar moved to maybe the guide or On Now tab. I often don't naturally think I should have to go into the DVR management tab to search for a show.
Just my two cents a couple minor things. Thanks for all you guys do!
Chris Olson
I agree that having the recordings split up like that is not intuitive and causes confusion.
I too love Channels, but let's make it even better!
