I’ve added a second HDHomerun Connect Duo to my configuration. I was going to use it with a second antenna which points in a different direction in order to receive those channels better. That portion set up fine, but when I added the HDHomerun to Channels via my Apple TV, it appears as though the Guide is only for the HDHomerun that is configured with a higher priority. When I change the priority of the two tuners, the Guide changes based on the channels available on that higher priority tuner. I saw the announcement from a previous release where it stated that there is one unified guide, but for some reason I don’t see that. Is there something I’m missing?
Dan
