Hi, I’ve noticed that I’m only getting approximately 10 days guide data in the U.K., is this expected? I thought the guide data would be 2 weeks, 14 days.
Maybe it was still downloading?
I don’t think so, the log file shows that the guide data had finished downloading around 4:25 am.
Seems to be mainly the 5 he channels that have no guide data beyond 8 days. I’ll check again tomorrow.
Just checked guide data this morning, it seems like large sections of guide data are unavailable from 31st May onwards?
I am seeing lots of "to be announced" from Monday 29th May
Yes same here
I see, “To Be Announced” is different than missing data. This probably means our guide data provider is working on some updates. I will check with them if it’s not fixed in a couple days.
Ok thanks
Has this gotten any better or still an issue?
Hi, I’m still not getting 14 days, beyond about 7 days lots of to be announced appearing.
Yes same for me- still lots of to be announced beyond 7 days
I’m not sure if it’s related, but for the last 2-3 days or so I’ve been having trouble downloading guide data. There are lots of gaps, and sometimes re-downloading helps, sometimes not. Here is a log clip from this morning:
[details=Log]2017/06/05 09:36:19 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-05 9:30AM
2017/06/05 09:37:10 [DVR] indexed 195 airings (25 channels) [51s fetch, 0s index]
2017/06/05 09:37:23 [DVR] indexed 4 movies (2 channels) [12s fetch, 0s index]
2017/06/05 09:37:23 [DVR] pruned 139 replaced airings in 0s.
2017/06/05 09:37:23 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-05 3:30PM
2017/06/05 09:38:14 [DVR] indexed 147 airings (20 channels) [50s fetch, 0s index]
2017/06/05 09:38:25 [DVR] indexed 4 movies (3 channels) [10s fetch, 0s index]
2017/06/05 09:38:25 [DVR] pruned 205 replaced airings in 0s.
2017/06/05 09:38:25 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-05 9:30PM
2017/06/05 09:39:08 [DVR] indexed 24 airings (5 channels) [42s fetch, 0s index]
2017/06/05 09:39:12 [DVR] indexed 1 movies (1 channels) [4s fetch, 0s index]
2017/06/05 09:39:12 [DVR] pruned 207 replaced airings in 0s.
2017/06/05 09:39:12 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-06 3:30AM
2017/06/05 09:40:03 [DVR] indexed 218 airings (31 channels) [50s fetch, 0s index]
2017/06/05 09:40:04 [DVR] indexed 1 movies (1 channels) [0s fetch, 0s index]
2017/06/05 09:40:04 [DVR] pruned 204 replaced airings in 0s.
2017/06/05 09:40:04 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-06 9:30AM
2017/06/05 09:40:55 [DVR] indexed 155 airings (20 channels) [50s fetch, 0s index]
2017/06/05 09:40:55 [DVR] indexed 4 movies (1 channels) [0s fetch, 0s index]
2017/06/05 09:40:56 [DVR] pruned 87 replaced airings in 0s.
2017/06/05 09:40:56 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-06 3:30PM
2017/06/05 09:41:47 [DVR] indexed 246 airings (35 channels) [50s fetch, 0s index]
2017/06/05 09:41:54 [DVR] indexed 14 movies (4 channels) [7s fetch, 0s index]
2017/06/05 09:41:54 [DVR] pruned 13 replaced airings in 0s.
2017/06/05 09:41:54 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-06 9:30PM
2017/06/05 09:42:45 [DVR] indexed 111 airings (17 channels) [50s fetch, 0s index]
2017/06/05 09:42:46 [DVR] indexed 6 movies (2 channels) [1s fetch, 0s index]
2017/06/05 09:42:46 [DVR] pruned 93 replaced airings in 0s.
2017/06/05 09:42:46 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-07 3:30AM
2017/06/05 09:43:31 [DVR] indexed 167 airings (26 channels) [45s fetch, 0s index]
2017/06/05 09:43:37 [DVR] indexed 6 movies (3 channels) [6s fetch, 0s index]
2017/06/05 09:43:38 [DVR] pruned 643 replaced airings in 0s.
2017/06/05 09:43:38 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-07 9:30AM
2017/06/05 09:44:22 [DVR] indexed 174 airings (24 channels) [43s fetch, 0s index]
2017/06/05 09:44:27 [DVR] indexed 8 movies (3 channels) [5s fetch, 0s index]
2017/06/05 09:44:28 [DVR] pruned 657 replaced airings in 0s.
2017/06/05 09:44:28 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-07 3:30PM
2017/06/05 09:45:17 [DVR] Error fetching guide data: unexpected end of JSON input
2017/06/05 09:45:17 [DVR] Fetching guide data for 128 stations in GBR-0001305-DEFAULT @ 2017-06-07 9:30PM[/details]
Yes I have also started having this issue again over the last few days. I can try to post logs from mine when I get home again if useful.
I’ve just subscribed to the DVR feature and I’m seeing this issue too. Some areas of the Guide are blank (it doesn’t even say “to be announced”). Also, re-downloading the data fixed some gaps but also introduced others and I lost the channel logos for some channels.
EDIT: Also, I’ve noticed that when selecting the Guide Data Provider, I only get the option of “Freeview - Reigate”. This isn’t the correct transmitter for me. It should be “Freeview - Crystal Palace” or something similar, but that isn’t an option. The result is that some channels don’t map correctly.
If you enter an invalid zip code like “123”, it should list all the Freeview transmitters.
Hmm, in your log I see the guide downloaded around 9am. Is it happening around 9-11am every day? I thought I had changed UK guide data to download between 4-6am instead…
@jmdraper What is the timestamp in your log?
Mine fetched at 0454 this morning. No obvious errors in the log (copied below) but a cursory glance through the guide shows some issues. E.g. BBC 1 channel entirely missing from the guide for tomorrow.
2017/06/05 04:54:00 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-05 4:30AM
2017/06/05 04:55:08 [DVR] indexed 1006 airings (124 channels) [67s fetch, 1s index]
2017/06/05 04:55:10 [DVR] indexed 6 movies (3 channels) [1s fetch, 0s index]
2017/06/05 04:55:10 [DVR] pruned 24 replaced airings in 0s.
2017/06/05 04:55:10 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-05 10:30AM
2017/06/05 04:56:13 [DVR] indexed 960 airings (124 channels) [60s fetch, 1s index]
2017/06/05 04:56:18 [DVR] indexed 24 movies (12 channels) [5s fetch, 0s index]
2017/06/05 04:56:18 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-05 4:30PM
2017/06/05 04:57:10 [DVR] indexed 739 airings (92 channels) [50s fetch, 0s index]
2017/06/05 04:57:17 [DVR] indexed 14 movies (11 channels) [7s fetch, 0s index]
2017/06/05 04:57:17 [DVR] pruned 181 replaced airings in 0s.
2017/06/05 04:57:17 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-05 10:30PM
2017/06/05 04:58:09 [DVR] indexed 585 airings (88 channels) [50s fetch, 0s index]
2017/06/05 04:58:16 [DVR] indexed 24 movies (13 channels) [6s fetch, 0s index]
2017/06/05 04:58:16 [DVR] pruned 238 replaced airings in 0s.
2017/06/05 04:58:16 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-06 4:30AM
2017/06/05 04:59:07 [DVR] indexed 785 airings (89 channels) [50s fetch, 0s index]
2017/06/05 04:59:08 [DVR] indexed 1 movies (1 channels) [0s fetch, 0s index]
2017/06/05 04:59:08 [DVR] pruned 182 replaced airings in 0s.
2017/06/05 04:59:08 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-06 10:30AM
2017/06/05 05:00:00 [DVR] indexed 777 airings (102 channels) [50s fetch, 0s index]
2017/06/05 05:00:04 [DVR] indexed 21 movies (9 channels) [3s fetch, 0s index]
2017/06/05 05:00:04 [DVR] pruned 166 replaced airings in 0s.
2017/06/05 05:00:04 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-06 4:30PM
2017/06/05 05:00:56 [DVR] indexed 614 airings (83 channels) [50s fetch, 0s index]
2017/06/05 05:01:00 [DVR] indexed 18 movies (9 channels) [4s fetch, 0s index]
2017/06/05 05:01:00 [DVR] pruned 331 replaced airings in 0s.
2017/06/05 05:01:00 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-06 10:30PM
2017/06/05 05:01:52 [DVR] indexed 724 airings (108 channels) [50s fetch, 0s index]
2017/06/05 05:01:57 [DVR] indexed 25 movies (12 channels) [5s fetch, 0s index]
2017/06/05 05:01:57 [DVR] pruned 104 replaced airings in 0s.
2017/06/05 05:01:57 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-07 4:30AM
2017/06/05 05:02:48 [DVR] indexed 713 airings (92 channels) [50s fetch, 0s index]
2017/06/05 05:02:49 [DVR] indexed 3 movies (2 channels) [0s fetch, 0s index]
2017/06/05 05:02:50 [DVR] pruned 238 replaced airings in 0s.
2017/06/05 05:02:50 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-07 10:30AM
2017/06/05 05:03:54 [DVR] indexed 955 airings (124 channels) [63s fetch, 1s index]
2017/06/05 05:04:00 [DVR] Starting job 1496635440-7 Location, Location, Location on ch=[104]
2017/06/05 05:04:00 [DVR] Waiting 16h55m59.848753103s until next job 1496696400-26 BBC News at Ten
2017/06/05 05:04:00 [DVR] indexed 28 movies (13 channels) [6s fetch, 0s index]
2017/06/05 05:04:00 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-07 4:30PM
2017/06/05 05:04:01 [TNR] Opened connection to 123079C7 for ch104
2017/06/05 05:04:01 [DVR] Recording for job 1496635440-7 from 123079C7 ch104 into "TV/Location, Location, Location/2017-06-05-0504 Location, Location, Location 2010-08-03.mpg" for 58m59.848705308s
2017/06/05 05:04:52 [DVR] indexed 871 airings (112 channels) [50s fetch, 1s index]
2017/06/05 05:04:57 [DVR] indexed 19 movies (12 channels) [5s fetch, 0s index]
2017/06/05 05:04:57 [DVR] pruned 56 replaced airings in 0s.
2017/06/05 05:04:57 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-07 10:30PM
2017/06/05 05:05:49 [DVR] indexed 734 airings (110 channels) [50s fetch, 0s index]
2017/06/05 05:05:56 [DVR] indexed 30 movies (17 channels) [7s fetch, 0s index]
2017/06/05 05:05:56 [DVR] pruned 83 replaced airings in 0s.
2017/06/05 05:05:56 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-08 4:30AM
2017/06/05 05:06:48 [DVR] indexed 816 airings (92 channels) [50s fetch, 0s index]
2017/06/05 05:06:49 [DVR] indexed 2 movies (2 channels) [1s fetch, 0s index]
2017/06/05 05:06:50 [DVR] pruned 146 replaced airings in 0s.
2017/06/05 05:06:50 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-08 10:30AM
2017/06/05 05:07:41 [DVR] indexed 871 airings (108 channels) [50s fetch, 1s index]
2017/06/05 05:07:45 [DVR] indexed 19 movies (10 channels) [3s fetch, 0s index]
2017/06/05 05:07:45 [DVR] pruned 68 replaced airings in 0s.
2017/06/05 05:07:45 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-08 4:30PM
2017/06/05 05:08:43 [DVR] indexed 946 airings (124 channels) [56s fetch, 1s index]
2017/06/05 05:08:47 [DVR] indexed 24 movies (11 channels) [4s fetch, 0s index]
2017/06/05 05:08:47 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-08 10:30PM
2017/06/05 05:09:27 [DVR] indexed 746 airings (124 channels) [38s fetch, 0s index]
2017/06/05 05:09:30 [DVR] indexed 26 movies (9 channels) [2s fetch, 0s index]
2017/06/05 05:09:30 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-09 4:30AM
2017/06/05 05:10:21 [DVR] indexed 880 airings (119 channels) [50s fetch, 1s index]
2017/06/05 05:10:23 [DVR] indexed 8 movies (4 channels) [1s fetch, 0s index]
2017/06/05 05:10:23 [DVR] pruned 43 replaced airings in 0s.
2017/06/05 05:10:23 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-09 10:30AM
2017/06/05 05:11:12 [DVR] indexed 923 airings (124 channels) [47s fetch, 1s index]
2017/06/05 05:11:15 [DVR] indexed 26 movies (11 channels) [3s fetch, 0s index]
2017/06/05 05:11:15 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-09 4:30PM
2017/06/05 05:12:07 [DVR] indexed 923 airings (124 channels) [50s fetch, 1s index]
2017/06/05 05:12:16 [DVR] indexed 30 movies (17 channels) [9s fetch, 0s index]
2017/06/05 05:12:17 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-09 10:30PM
2017/06/05 05:13:11 [DVR] indexed 775 airings (124 channels) [53s fetch, 0s index]
2017/06/05 05:13:20 [DVR] indexed 41 movies (23 channels) [8s fetch, 0s index]
2017/06/05 05:13:20 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-10 4:30AM
2017/06/05 05:14:10 [DVR] indexed 977 airings (124 channels) [48s fetch, 1s index]
2017/06/05 05:14:12 [DVR] indexed 14 movies (8 channels) [2s fetch, 0s index]
2017/06/05 05:14:12 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-10 10:30AM
2017/06/05 05:15:03 [DVR] indexed 900 airings (124 channels) [48s fetch, 1s index]
2017/06/05 05:15:10 [DVR] indexed 32 movies (20 channels) [7s fetch, 0s index]
2017/06/05 05:15:10 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-10 4:30PM
2017/06/05 05:15:58 [DVR] indexed 818 airings (124 channels) [46s fetch, 1s index]
2017/06/05 05:16:06 [DVR] indexed 54 movies (26 channels) [8s fetch, 0s index]
2017/06/05 05:16:06 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-10 10:30PM
2017/06/05 05:16:46 [DVR] indexed 730 airings (124 channels) [38s fetch, 0s index]
2017/06/05 05:16:55 [DVR] indexed 49 movies (29 channels) [8s fetch, 0s index]
2017/06/05 05:16:55 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-11 4:30AM
2017/06/05 05:17:42 [DVR] indexed 981 airings (124 channels) [45s fetch, 1s index]
2017/06/05 05:17:46 [DVR] indexed 11 movies (8 channels) [4s fetch, 0s index]
2017/06/05 05:17:47 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-11 10:30AM
2017/06/05 05:18:33 [DVR] indexed 876 airings (124 channels) [45s fetch, 1s index]
2017/06/05 05:18:39 [DVR] indexed 36 movies (20 channels) [6s fetch, 0s index]
2017/06/05 05:18:39 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-11 4:30PM
2017/06/05 05:19:25 [DVR] indexed 862 airings (124 channels) [44s fetch, 1s index]
2017/06/05 05:19:31 [DVR] indexed 49 movies (21 channels) [5s fetch, 0s index]
2017/06/05 05:19:31 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-11 10:30PM
2017/06/05 05:20:07 [DVR] indexed 805 airings (124 channels) [35s fetch, 0s index]
2017/06/05 05:20:13 [DVR] indexed 36 movies (17 channels) [5s fetch, 0s index]
2017/06/05 05:20:13 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-12 4:30AM
2017/06/05 05:21:01 [DVR] indexed 979 airings (124 channels) [47s fetch, 1s index]
2017/06/05 05:21:05 [DVR] indexed 9 movies (6 channels) [3s fetch, 0s index]
2017/06/05 05:21:08 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-24 10:30PM
2017/06/05 05:21:34 [DVR] indexed 433 airings (124 channels) [25s fetch, 0s index]
2017/06/05 05:21:35 [DVR] indexed 8 movies (3 channels) [1s fetch, 0s index]
2017/06/05 05:21:35 [DVR] pruned 7 replaced airings in 0s.
2017/06/05 05:21:35 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-25 10:30AM
2017/06/05 05:21:56 [DVR] indexed 361 airings (99 channels) [20s fetch, 0s index]
2017/06/05 05:21:57 [DVR] indexed 4 movies (2 channels) [0s fetch, 0s index]
2017/06/05 05:21:57 [DVR] pruned 9 replaced airings in 0s.
2017/06/05 05:21:57 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-25 4:30PM
2017/06/05 05:22:04 [DVR] indexed 111 airings (42 channels) [6s fetch, 0s index]
2017/06/05 05:22:05 [DVR] indexed 2 movies (2 channels) [0s fetch, 0s index]
2017/06/05 05:22:05 [DVR] Fetching guide data for 124 stations in GBR-0001204-DEFAULT @ 2017-06-25 10:30PM
2017/06/05 05:22:07 [DVR] indexed 27 airings (8 channels) [1s fetch, 0s index]
2017/06/05 05:22:07 [IDX] Pruned 77 expired groups from GBR-0001204-DEFAULT in 23.918795ms.
2017/06/05 05:22:07 [DVR] Deleting job with expired serial: 1496779140-3 Timeshift (EP012708610044)
2017/06/05 05:22:07 [DVR] Deleting job with expired serial: 1496782800-26 BBC News at Ten (SH012596880000-1496782800)
2017/06/05 05:22:07 [DVR] Waiting 16h37m52.52097795s until next job 1496696400-26 BBC News at Ten
2017/06/05 05:22:08 [IDX] Pruned 820 expired airings from GBR-0001204-DEFAULT in 898.0534ms.
This is the issue… we’re requesting 124 stations worth of data, but only receiving 92 back.
I’ll try changing the time again, to download around midnight.
[quote=“tmm1, post:16, topic:1652”]
[/quote] It’s automatically downloading between 4 and 5 AM as usual, but there have been significant gaps in the data for the past 2-3 days. The log I posted was from a manual download I started this morning to see if it would fill in the missing data, but as you can see there were still a lot of data missing. I tried another download around 4 PM this afternoon, and that time the data was pretty much complete. I’m not sure what’s changed in the past couple days.
Hmm, I entered “123” and I can see the whole list, but my transmitter is not listed…
