U-verse channels not authorized
Channels saying not authorized for ATT U-verse. Rescanned only 68 channels now. Deleted and re entered same thing. Updated windows 10, turned computer completely off the back on same thing. Uverse app works fine on my phone. Philo works fine on channels app just not Att U-verse.
If you go to the website of one of those channels are you able to log in with your U-Verse credentials and watch live?
I’m not sure how to go to the website. App on USA network not working on Apple TV or iPhone if that helps. I’m not very Saavy in these things. But willing to learn. Usa is just one of the channel’s that’s not working.
No. I cannot. Say channel needs to be added to package. Package has not changed. 69 channels still work. Mostly junk channels
If you go to https://www.usanetwork.com/live and login with your U-Verse credentials and it doesn't work, then it's an issue with AT&T U-Verse authenticating you.
I don't have U-Verse, but when I go to the USA TV Live site and select AT&T U-Verse I get this error.
Unable to connect - can't establish a connection to the server at cprodmasx.att.com.
Just wanted to update that it's working now (sign in with AT&T U-Verse).
It takes me to AT&T to sign in.
May have been a brief outage with their auth servers.
Also NBC Live https://www.nbc.com/live working to take you to AT&T signin
