Ubuntu issues
Channes DVR broke today? I cannot reinstall
erich@erich-Vostro-1520:~$ curl -f -s https://getchannels.com/dvr/setup.sh | sh
Downloading Channels DVR 2017.02.15.0045 (linux-x86_64) to /home/erich/channels-dvr…
ERROR: Installation of Channels DVR failed.
ERROR: Please contact [email protected] with the full output above.
Can you run:
curl -f -s https://getchannels.com/dvr/setup.sh | sh -x
Is it still installed from before? Did you check the log to see what broke?
I can’t access the log.
The log is available on the linux box, in ./channels-dvr/data/channels-dvr.log.
I suspect the re-install is failing because the server is still running.
I got it working after a reboot. The Congrats. your up and running doesn’t show the local acces point any longer?
Could be a bug where it doesn’t show up after a reboot.
