I was wondering if anyone else in the UK was having the same issue as me after being forced by hdhomerun to update firmware. So basically, where I live is close to the English Welsh border and since using Channels DVR for many years, I was disabling the channels from the hdhomerun scan and replacing them with an m3u that had the BBC, ITV and Channel 4 channels for both English and Welsh. Since the update tonight, I couldn't play an of the BBC, ITV etc channels. So I tried disabling my m3u and reanabling the original channels and they work again. Problem is I can't get the Welsh channels now, please help.
Do a rescan?
Tried and didn't work. Also removed the hdhomerun from channels but then when I added it back, it couldn't find it. Had to then restore a previous database. I think it's the way hdhomerun and Freeview now handle the signal. The issue is hdhomerun sometimes rescsns in the background and I'll end up with the wrong lineup cos even though technically it's the same channel, some TV schedules are slightly different.
Ok, are you able to watch on the HDHomerun app?
Maybe try exporting the HDHomerun playlist and adding it as a custom channel?? If that doesn't work, its a HDHR issue...and you may need to reach out to Silicondust
Thanks, I can watch it on the hdhomerun app. I'll reach out to them. Thanks for your help
