The guide data for Freesat in the UK does not include Channel 4 HD (on channel 126) - what is the right way to get this fed back to the guide provider please?
It does exist in some of the other providers so the guide provider is aware of the channel, but then the rest of those listings do not exactly match as it is the wrong guide overall so not a solution really.
What is strange about this is that it has been missing since it was added almost a year ago - it's quite surprising that it has not been resolved as presumably every consumer of that guide has it missing. e.g. I think Channels uses the same provider as Plex which also has the same problem.
What is more curious is that other channels have been added since Channel 4 HD was added to the Freesat line up - for example E4 Extra on channel 181 only started a few months ago and appears in the guide fine. E4 and Channel 4 are the same broadcaster so why wouldn't Channel 4 HD be in the listing?
Channel 4 HD is one of the largest channels in the UK. For now I can map it to the SD version on 104 as I think 99% of the programming is the same - at least at primetime. But it would be good to get this properly resolved if possible especially for metadata purposes - happy to do the leg work to the guide provider if I can be pointed in the right direction.
You can see it missing in the following screen shot:
(p.s. there are a couple of minor channels missing as well but C4HD is the biggest gap so focusing on that for now ...)
