Hello,
I’m missing guide data for freeview channel 7 - Tyne & Wear TV. I’ve tried entering in my post code and selecting Freeview but there is still no data for this channel.
Many thanks,
Gareth
Hello,
Many thanks,
Gareth
Does the official HDHR app show guide data for that channel?
No -it doesn’t.
Can you contact them to see if the guide provider can add it?
Will do!!
That’s done. I’ve now got guide data in the Hdhomerun app but not in channels. Do I need to do something to get it to show up for Channels DVR?
Yeah I have listings fine in the HDHomeRun app!
The latest DVR pre-release has the ability to import missing stations from SiliconDust. Please update your DVR to v2018.10.02.1857 by holding down SHIFT and clicking Check for Updates on the web UI. After the update completes, click the circle refresh icon under your HDHR and it should pull guide data for channel 7.
