UK freeview guide
The UK freeview guide is only populated 2 days ahead - is this a bug or is there any setting to enable it to 7 or 14 days
Where are you looking? Check the web UI of the DVR on the Guide tab. You should see 21 days of data via the drop down that says “Today”
Looking on ATV guide - should that be showing 14/21 days ahead ?
Will check web guide later
Yes it should. Checking web ui will narrow down the issue.
