Hey everyone!
Gracenote is having an issue with some of their UK lineups. They aren't reporting any guide data.
If you've run into this issue, there's a simple fix:
- Go into your Channels DVR Server settings and find your HDHomeRun.
- Click the the trash can button to remove it's lineup.
- Go through and search for the new lineup for your area and add it.
- Just to be on the safe side, then go down to the Guide Database section and choose Re-Download Entire Guide.
Your passes and scheduled recordings will not be effected.
