I’m having the same problem with 2 DVB-T2 CONNECTS in the UK. A number of channels are present above 5000. Some have the names of real channels such as “BBC ONE HD” but many are just “Unknown”. Obviously the cable card issue doesn’t apply to the Connect. Any one else had this issue?
Also the number of channels on each connect is different 207 channels on 1 and 250 on the other. Each is running the same firmware and is using the same roof aerial with a splitter pointed at Emley Moor with line of sight and 100% signal strength.
