This is my first support request post so if posted to wrong place, apologizes and appreciate guidance on how should actually be done.
I just moved my Channels DVR server to a mac mini from Nvidia Shield after the 9.0 Shield upgrade debacle. I am using 2 dual tuner OTA tuners and a TVE login using Uverse. I had one TVE channel that wasnt coming through, so tried to refresh it but then got errors which suggested that I needed to install Chrome on my mac. I installed Chrome and then tried again but now get "Failed to start stream for ch6104: TVE: TypeError: Illegal invocation" errors. I then tried to rescan and refresh another TVE channel, and now get similar "Failed to start stream for ch6105: TVE: TypeError: Illegal invocation" errors. I feel if I do that function on any TVE channel, it will then break the feed even if already working. Something seems amiss in my MAc/Chrome/CHannels configuration.
Appreciate any assistance as my wife really wants to get back to HGTV without haviung to use the HGTVgo app and watch commercials.
Click Check for Update > Prerelease
Having recently gone through the migration to a different computer for the DVR server, two things to do:
- Make sure you are connected to your DVR server via
HTTPS. (Don't worry if your browser complains about the certificate; this is just to ensure that your browser will use location services properly for locals and Eastern/Pacific geolocation.) - Ensure that your DVR server is running the latest pre-release version. (As I write this, that is version
2022.03.19.0040). - Use the Rescan All Channels option for your TVE sources, as the new OS/browser will make reauthentication necessary for nearly all channels.
Thanks for the suggestions. I did Rescan All and I lost about 30 channels. But I can login directly to the associated app that each channel (HGTV, TLC, etc) with my paid provider successfully. Is it just that TVE no longer supports them or something else? Happy to submit logs.
See above:
Im noticing that i lost bout 80 channels as well.
On latest prerelease, did a full rescan and got 80 of 188 channels back.
Im on cox. Anyone else seeing this?
I was at the latest reuse version which was a February date. I did go to the latest prerelease and that seems to have resolved things. Thanks
