Unable to install DVR engine
Hello. I’m still on version 8.2.3 on my Shield.
I am trying to move my server from one Shield to another. So I stopped the DVR on the old one, and plugged my hard drive on the new Shield.
So when I try to start the DVR engine for the first time, it hangs at “Downloading DVR engine”.
What should I do?
Maybe its not getting a good network connection. Can you try the speedtest app?
Looks good to me…
I see a have the beta version of Channels. I wanted to try with the regular version but I didn’t find how to do it. All I see in the play store is the beta
You have to click "Leave" on Sign in - Google Accounts
That's not going to help though.
I would say reboot the device, then click Download and let it sit there until it can finish
I rebooted and it sat there for about an hour. Should it take this long?
Only if its having a hard time downloading..
Are you using custom DNS or VPN or something?
No custom DNS and no VPN.
I'll try again tomorrow and I'll let it sit for a while
So, I just tried this morning using the regular version (not beta), and the DVR installed in less than 10 seconds...
