Unable to play m3u stream outside home network
hello. i am running into a problem with accessing a video stream from outside of my home network. i am running a server application on the same windows 11 machine where i am running the channels dvr server. the application works great when i am on my home network in that it provides me with a video stream from my slingbox that i can access via vlc and also from channels when i add it as a custom m3u channel.
when i try to access it from my cell phone over lte it is timing out as per the logs below. i have forwarded the port on my router to the server application using a different port from which channels uses. i am also able to access the server application from vlc from my home network if i use the ip address from my isp.
is there any way to increase the timeout as it appears that this might be my problem.
2022/09/30 09:30:24.778197 [TNR] Opened connection to M3U-Slingbox for ch9000 OS 10 SB500
2022/09/30 09:30:58.961692 [SNR] Buffer statistics for 192.XXX.XXX.XXX (iPhone) for ch9000 OS 10 SB500: buf=0% drop=0%
2022/09/30 09:30:58.962204 [TNR] Closed connection to M3U-Slingbox for ch9000 OS 10 SB500
2022/09/30 09:31:57.598268 [TNR] Opened connection to M3U-Slingbox for ch9000 OS 10 SB500
2022/09/30 09:31:57.605171 [HLS] Starting live stream for channel 9000 from 174.XXX.XXX.XXX (bitrate=0)
2022/09/30 09:32:07.741467 [HLS] Probe failed for live stream after 10.1362957s and 2089704 bytes
2022/09/30 09:32:13.691046 [HLS] Couldn't generate stream playlist for ch9000-dANY-bca066497710: Timeout waiting for session to start after 8s
2022/09/30 09:32:13.691046 [HLS] Stopping transcoder session ch9000-dANY-bca066497710 (out: 0s, finished: false)
2022/09/30 09:32:13.691046 [TNR] Closed connection to M3U-Slingbox for ch9000 OS 10 SB500
2022/09/30 09:32:13.706294 [SNR] Buffer statistics for ch9000 OS 10 SB500: buf=0% drop=0%
if anyone is interested in using their slingboxes after sling shuts down in nov see this thread. this app works great and you will also be able to integrate it with channels GitHub - GerryDazoo/Slinger: Reuse SlingBox hardware without SlingBox Servers
thanks !!
