I have Personal Videos on a Synology NAS server and I am trying to import them into Channels running on a Windows box. Some videos are in a folder named Home Movies. The videos will import, but the folder name is ignored and all videos are placed in a Group with name /. Root. I assume it’s because of the space in the folder name. I have tried many different ways to name the Path - quotes, %20, etc. but nothing seems to work. Any ideas?
Please submit diagnostics so we can take a look
Ok. Done.
de2581c7-095e-4689-bb85-53212f942229
Any ideas on this?
I don't see anything imported in your diagnostics?
Spaces are fine I don't think that's related
Okay, I just did and import called Home Movies and it named the group /.
Here is the log. e378f78f-3a5b-4cd4-a663-09fe7fd2f81c
Thanks I see it now, looks like a funky bug of some sort
I will take a look, but one alternative would be to use a mapped drive
OK. I will give that a try, as well.
I tried using a Mapped drive H: and had the same result.
Can you submit diagnostic with that setup
OK.
62a9a0ae-8565-487c-af2c-50f74b592364 .
