Undo commercial detection
I made a mistake and ran commercial detection against some movies that do not have commercials..... it detected some (even though there are none). there are no edl files, so i assume they are stored in a DB some place.... how can I undo this so they do not have the markers?
The movies currently sit in the imports directory.
You do it from the DVR admin web UI.
Find the Movie and select More Options > Edit Commercials.
Just mark every section as show material and save it.
Thank you.
