Unknown in guide and some channels as a result (Comcast minneapolis)
Any idea why some channels are self identifying but not pulling down guide info:
TLC HD
SYFY HD
USA HD
TBS HD
FOOD HD
HGTV HD
does the matching method ignore “hd”?
Side note they’re tuning fine.
Could be an issue with SiliconDust guide data. Please email [email protected] with your HDHomeRun device ID and the channels that are not showing guide data.
I assume you are using a PRIME with a cable card, and that you see the SiliconDust logo on the Settings page.
Disregard. I rescanned for channels after the firmware update. Small pro tip if anyone sees this in the future.
