Unplayable recording and incorrect length
I have been testing the DVR Beta since the public beta was released and have had a mostly perfect experience. Thank you!
However, last night a recording started as scheduled. I later noticed when I went to watch it that the length the recording listed on the Apple TV was 24 hrs. The recording was also unplayable. When I check the file on my Mac in Finder the length seems correct, but the file is still unplayable.
Wanted to check if this is a fluke or possible bug.
Here is my current log:
[mpegts @ 0x7f9ebb80aa00] PES packet size mismatch
[mpegts @ 0x7f9ebb80aa00] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7f9ebb80aa00] Dropped corrupted packet (stream = 2)
Last message repeated 1 times
Last message repeated 2 times
Last message repeated 3 times
Last message repeated 4 times
2017/01/18 15:23:13 [HLS] Stopping transcoder session file-13
2017/01/18 15:23:13 [HLS] error during ffmpeg progress: unexpected EOF
Thank you!
Kevin
What channel/show was this on? How long was the recording supposed to be?
Can you play it back using VLC on your mac?
The show was New Girl on FOX (OTA). It should have been 30 minutes. I am unable to get it to playback in VLC. Other shows recorded fine later last night and are playable.
Perhaps there was a bad OTA signal at the time the recording was made?
What’s the file size?
Does VLC show any errors when you try to play it?
Visit http://localhost:8089/dvr/files/13/mediainfo.json (replacing localhost with the ip of your DVR), and post the results.
File size is 1.76 GB. I don’t see an error in VLC.
{“format”:{“bit_rate”:“164939”,“duration”:“85258.724978”,“filename”:"/Volumes/Elements/Channels Recordings/TV/New Girl/2017-01-17-1901 New Girl 2017-01-17 S06E13 Ceces Boys.mpg",“format_long_name”:“MPEG-TS (MPEG-2 Transport Stream)”,“format_name”:“mpegts”,“nb_programs”:1,“nb_streams”:14,“probe_score”:50,“size”:“1757816732”,“start_time”:“64584.942767”},“streams”:[{“avg_frame_rate”:“0/0”,“codec_tag”:“0x0031”,“codec_tag_string”:“1[0][0][0]”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x100e”,“index”:0,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“185/12”,“bit_rate”:“4089446400”,“chroma_location”:“left”,“codec_long_name”:“MPEG-2 video”,“codec_name”:“mpeg2video”,“codec_tag”:“0x0002”,“codec_tag_string”:"[2][0][0][0]",“codec_time_base”:“12/185”,“codec_type”:“video”,“coded_height”:0,“coded_width”:0,“color_range”:“tv”,“display_aspect_ratio”:“0:1”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“1746.169400”,“duration_ts”:1.57155246e+08,“field_order”:“bb”,“has_b_frames”:1,“height”:744,“id”:“0x31”,“index”:1,“level”:4,“pix_fmt”:“yuv420p”,“profile”:“Main”,“r_frame_rate”:“240000/58058”,“refs”:1,“sample_aspect_ratio”:“0:1”,“start_pts”:5.812680076e+09,“start_time”:“64585.334178”,“time_base”:“1/90000”,“width”:1280},{“avg_frame_rate”:“0/0”,“bit_rate”:“448000”,“bits_per_sample”:0,“channel_layout”:“5.1(side)”,“channels”:6,“codec_long_name”:“ATSC A/52A (AC-3)”,“codec_name”:“ac3”,“codec_tag”:“0x332d4341”,“codec_tag_string”:“AC-3”,“codec_time_base”:“1/48000”,“codec_type”:“audio”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“dmix_mode”:"-1",“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x34”,“index”:2,“loro_cmixlev”:"-1.000000",“loro_surmixlev”:"-1.000000",“ltrt_cmixlev”:"-1.000000",“ltrt_surmixlev”:"-1.000000",“r_frame_rate”:“0/0”,“sample_fmt”:“fltp”,“sample_rate”:“48000”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“tags”:{“language”:“eng”},“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x0035”,“codec_tag_string”:“5[0][0][0]”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x101e”,“index”:3,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x000c”,“codec_tag_string”:"[12][0][0][0]",“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x131”,“index”:4,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x0038”,“codec_tag_string”:“8[0][0][0]”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x5ff”,“index”:5,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“bits_per_sample”:0,“channels”:0,“codec_long_name”:“ATSC A/52A (AC-3)”,“codec_name”:“ac3”,“codec_tag”:“0x0081”,“codec_tag_string”:"[129][0][0][0]",“codec_time_base”:“1/0”,“codec_type”:“audio”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“dmix_mode”:"-1",“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0xb4”,“index”:6,“loro_cmixlev”:"-1.000000",“loro_surmixlev”:"-1.000000",“ltrt_cmixlev”:"-1.000000",“ltrt_surmixlev”:"-1.000000",“r_frame_rate”:“0/0”,“sample_rate”:“0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_long_name”:“MPEG-2 video”,“codec_name”:“mpeg2video”,“codec_tag”:“0x0002”,“codec_tag_string”:"[2][0][0][0]",“codec_time_base”:“0/1”,“codec_type”:“video”,“coded_height”:0,“coded_width”:0,“display_aspect_ratio”:“0:0”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“has_b_frames”:0,“height”:0,“id”:“0x1c31”,“index”:7,“level”:-99,“r_frame_rate”:“90000/1”,“refs”:1,“sample_aspect_ratio”:“0:1”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”,“width”:0},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x00ff”,“codec_tag_string”:"[255][0][0][0]",“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x1f00”,“index”:8,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_long_name”:“binary data”,“codec_name”:“bin_data”,“codec_tag”:“0x0006”,“codec_tag_string”:"[6][0][0][0]",“codec_type”:“data”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x1bd”,“index”:9,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x00c2”,“codec_tag_string”:"[194][0][0][0]",“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x1e31”,“index”:10,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x0054”,“codec_tag_string”:“T[0][0][0]”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x62d”,“index”:11,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”},{“avg_frame_rate”:“0/0”,“codec_long_name”:“MPEG-2 video”,“codec_name”:“mpeg2video”,“codec_tag”:“0x0002”,“codec_tag_string”:"[2][0][0][0]",“codec_time_base”:“0/1”,“codec_type”:“video”,“coded_height”:0,“coded_width”:0,“display_aspect_ratio”:“0:0”,“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“has_b_frames”:0,“height”:0,“id”:“0x25”,“index”:12,“level”:-99,“r_frame_rate”:“90000/1”,“refs”:1,“sample_aspect_ratio”:“0:1”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”,“width”:0},{“avg_frame_rate”:“0/0”,“codec_tag”:“0x00d7”,“codec_tag_string”:"[215][0][0][0]",“disposition”:{“attached_pic”:0,“clean_effects”:0,“comment”:0,“default”:0,“dub”:0,“forced”:0,“hearing_impaired”:0,“karaoke”:0,“lyrics”:0,“original”:0,“timed_thumbnails”:0,“visual_impaired”:0},“duration”:“85258.724978”,“duration_ts”:7.673285248e+09,“id”:“0x1683”,“index”:13,“r_frame_rate”:“0/0”,“start_pts”:5.812644849e+09,“start_time”:“64584.942767”,“time_base”:“1/90000”}]}
Interesting. There appear to be multiple video tracks in the file.
What hdhomerun model was this?
It’s a Connect.
This happened again last night with the same show on the same channel. Other channels are working fine. I will test with another show on this channel tonight and see what happens.
Use this command to download 30mb sample of that last recording and then send it to [email protected]:
cd Desktop && curl -o sample.mpg -r 0-30000000 http://localhost:8089/dvr/files/13/stream.mpg
Make sure your HDHR is running the latest firmware too.
What HDHR model?
Does this channel tune correctly when you try to watch it live on the ATV?
I recorded Big Bang theory tonight and when I went to watch it, on the episode screen it said 173 minutes. When I started watching the commercial markers were wrong like a bunch of 15 second markers and it said 173 minutes. I went out and the. Back in and it had the right markers. The DVD log is clean, it showed that it found 12 markers and was finished before 8. I started at 9:50 the episode played fine.
I know I have see. This in the past and and just pawned it off on my eyes playing tricks on me.
Does VLC show the same length?
Well, yes, but I will have to try that before looking at the show, because, even the Apple TV shows the right length and visually fixed the commercials once I exited and re entered the episode screen.
I’m sure the file is fine because it hasn’t been touched since the episode was done. I can’t find anything that was actually modified at 9:50
Oh it was fine when you went back in. Sounds like a different bug then, maybe in the tvOS app.
@Kevinstillson Have you had this problem with any more recordings?
