I am running Channels DVR in a Docker container on my Unraid server v6.9.1 with a NVidia P2000 GPU in the server. I installed Channels DVR using the ChannelsDVR-NVidia template. I did the steps to edit /boot/config/go to add the line modprobe i915 , and configure your container to pass-through the /dev/dri device. Under Settings Transcoding only Software transcoding appears.
Hardware Transcoding works on my Plex server. Not sure why it's not working with Channels DVR. Anyone else with a similar setup that can help out?
