Unraid set up help
Hello,
I am attempting to transfer my database and recordings from a windows 10 pc to Unraid. I am having difficulty doing this and hoping the community can assist. I am new to Unraid.
  • Unraid is running
  • Channels dvr is installed,
  • I have placed my recordings in the correct shared folder (i think)
  • I have uncheck the DVR box, and I can get to the restore screen.
  • I do not know what to do at the restore screen. I have my most recent backup logs, both the folder and the 2 files, from my windows machine but I can not find a way to access them. Where to I need to put them in the unraid? Nothing I do allows me to access or open these files.
    Thank you for any assistance!
    unraid%20backup
It looks like you copied over some tv folders, but you need to copy over the entire DVR folder as-is. So there should be a Database folder and a TV folder and then the shows are inside the TV folder
Awesome. Thanks for the very prompt response. One day I will gain an understanding of this stuff....
