I have a bunch of entries in the log that say unexpected duration. They all seem from remote playback.
2021/01/13 18:46:15.661400 [ENC] Segment 460 has unexpected duration: inputs=998-999 expected=1 actual=1.12 expected_pts=459.984000-460.944000 actual_pts=460.005333-461.105333
2021/01/13 18:46:20.248654 [ENC] Segment 465 has unexpected duration: inputs=1008-1009 expected=1 actual=1.12 expected_pts=464.424000-465.384000 actual_pts=464.445333-465.545333
2021/01/13 18:46:29.147719 [ENC] Segment 474 has unexpected duration: inputs=1028-1029 expected=1 actual=1.12 expected_pts=473.424000-474.384000 actual_pts=473.445333-474.545333
2021/01/13 18:46:32.147596 [ENC] Segment 477 has unexpected duration: inputs=1034-1035 expected=1.08 actual=1.16 expected_pts=476.424000-477.464000 actual_pts=476.485333-477.625333
2021/01/13 18:46:33.730159 [HLS] Stopping transcoder session ch6160-dANY-8d8900a2a99b (out: 35.921944s, finished: false)
2021/01/13 18:46:33.730398 [HLS] ffmpeg: ch6160-dANY-8d8900a2a99b-remux: [mpegts @ 0x7facd4808200] Dropped corrupted packet (stream = 0)
2021/01/13 18:46:33.765061 [TNR] Closed connection to TVE-DTV for ch6160 OLYMPICS
2021/01/13 18:46:35.348563 [ENC] Segment 480 has unexpected duration: inputs=1040-1041 expected=1 actual=1.12 expected_pts=479.624000-480.584000 actual_pts=479.645333-480.745333
2021/01/13 18:46:45.298640 [TVE] stream timestamps: tennis: start_at=2021-01-13T18:46:19+11:00 current_at=2021-01-13T18:46:23+11:00 end_at=2021-01-13T18:46:31+11:00
2021/01/13 18:46:45.298711 [TNR] Opened connection to TVE-DTV for ch6155 TENNIS
2021/01/13 18:46:45.311237 [HLS] Starting transcoder for channel 6155 from 121.218.34.39 (encoder=remux, resolution=, deinterlacer=, bitrate=2969)
2021/01/13 18:46:46.727897 [HLS] Probed live stream in 1.415489525s: h264 1280x720 progressive 2826239bps
2021/01/13 18:46:46.770379 [HLS] Session ch6155-dANY-8d8900a2a99b started in 6.25810811s
2021/01/13 18:46:52.249952 [ENC] Segment 497 has unexpected duration: inputs=1077-1078 expected=1 actual=1.12 expected_pts=496.544000-497.504000 actual_pts=496.565333-497.665333
2021/01/13 18:47:03.165522 [ENC] Segment 508 has unexpected duration: inputs=1099-1100 expected=1 actual=1.12 expected_pts=507.504000-508.464000 actual_pts=507.525333-508.625333
2021/01/13 18:47:09.055628 [ENC] Segment 514 has unexpected duration: inputs=1111-1112 expected=1 actual=1.12 expected_pts=513.304000-514.264000 actual_pts=513.325333-514.425333
2021/01/13 18:47:13.251543 [ENC] Segment 518 has unexpected duration: inputs=1119-1120 expected=1 actual=1.12 expected_pts=517.504000-518.464000 actual_pts=517.525333-518.625333
2021/01/13 18:47:19.165075 [HLS] Stopping transcoder session ch6155-dANY-8d8900a2a99b (out: 40.874667s, finished: false)
2021/01/13 18:47:19.165408 [HLS] ffmpeg: ch6155-dANY-8d8900a2a99b-remux: [mpegts @ 0x7f8c13011c00] Dropped corrupted packet (stream = 0)
2021/01/13 18:47:19.185136 [TNR] Closed connection to TVE-DTV for ch6155 TENNIS
2021/01/13 18:47:20.381989 [ENC] Segment 525 has unexpected duration: inputs=1135-1136 expected=1 actual=1.12 expected_pts=525.064000-526.024000 actual_pts=525.085333-526.185333
2021/01/13 18:47:22.251836 [ENC] Segment 527 has unexpected duration: inputs=1139-1140 expected=1.08 actual=1.2 expected_pts=526.544000-527.584000 actual_pts=526.565333-527.745333
2021/01/13 18:47:38.249647 [ENC] Segment 543 has unexpected duration: inputs=1171-1172 expected=1.08 actual=1.2 expected_pts=542.544000-543.584000 actual_pts=542.565333-543.745333
2021/01/13 18:47:40.245825 [ENC] Segment 545 has unexpected duration: inputs=1175-1176 expected=1 actual=1.12 expected_pts=544.544000-545.504000 actual_pts=544.565333-545.665333
2021/01/13 18:47:47.446619 [ENC] Segment 552 has unexpected duration: inputs=1189-1191 expected=1 actual=1.06 expected_pts=551.784000-552.744000 actual_pts=551.745333-552.785333
2021/01/13 18:47:48.447750 [ENC] Segment 553 has unexpected duration: inputs=1192-1193 expected=1 actual=1.12 expected_pts=552.784000-553.744000 actual_pts=552.805333-553.905333
2021/01/13 18:47:51.449710 [ENC] Segment 556 has unexpected duration: inputs=1198-1199 expected=1 actual=1.12 expected_pts=555.784000-556.744000 actual_pts=555.805333-556.905333
2021/01/13 18:48:08.674474 [ENC] Segment 573 has unexpected duration: inputs=1234-1235 expected=1 actual=1.12 expected_pts=573.024000-573.984000 actual_pts=573.045333-574.145333
2021/01/13 18:48:19.744411 [ENC] Segment 585 has unexpected duration: inputs=1258-1259 expected=1 actual=1.12 expected_pts=584.024000-584.984000 actual_pts=584.045333-585.145333
2021/01/13 18:48:33.949652 [ENC] Segment 599 has unexpected duration: inputs=1288-1289 expected=1.12 actual=1.22 expected_pts=598.144000-599.224000 actual_pts=598.165333-599.365333
2021/01/13 18:48:40.044910 [ENC] Segment 605 has unexpected duration: inputs=1301-1302 expected=1 actual=1.12 expected_pts=604.344000-605.304000 actual_pts=604.365333-605.465333
2021/01/13 18:48:48.355521 [ENC] Segment 613 has unexpected duration: inputs=1317-1318 expected=1 actual=1.12 expected_pts=612.544000-613.504000 actual_pts=612.565333-613.665333
2021/01/13 18:48:51.950371 [ENC] Segment 617 has unexpected duration: inputs=1325-1326 expected=1 actual=1.12 expected_pts=616.624000-617.584000 actual_pts=616.645333-617.745333
2021/01/13 18:48:54.055173 [ENC] Segment 619 has unexpected duration: inputs=1329-1330 expected=1 actual=1.12 expected_pts=618.344000-619.304000 actual_pts=618.365333-619.465333
2021/01/13 18:49:03.656738 [ENC] Segment 628 has unexpected duration: inputs=1349-1350 expected=1 actual=1.12 expected_pts=627.384000-628.344000 actual_pts=627.405333-628.505333
2021/01/13 18:49:07.743958 [ENC] Segment 632 has unexpected duration: inputs=1359-1360 expected=1.08 actual=1.16 expected_pts=631.944000-632.984000 actual_pts=632.005333-633.145333
2021/01/13 18:49:13.461298 [ENC] Segment 638 has unexpected duration: inputs=1371-1372 expected=1 actual=1.12 expected_pts=637.824000-638.784000 actual_pts=637.845333-638.945333
2021/01/13 18:49:24.141223 [ENC] Segment 649 has unexpected duration: inputs=1393-1394 expected=1 actual=1.12 expected_pts=648.744000-649.704000 actual_pts=648.765333-649.865333
2021/01/13 18:49:27.168130 [ENC] Segment 652 has unexpected duration: inputs=1399-1400 expected=1 actual=1.12 expected_pts=651.304000-652.264000 actual_pts=651.325333-652.425333
2021/01/13 18:49:32.344936 [ENC] Segment 657 has unexpected duration: inputs=1409-1410 expected=1 actual=1.12 expected_pts=656.624000-657.584000 actual_pts=656.645333-657.745333
2021/01/13 18:49:39.546197 [ENC] Segment 664 has unexpected duration: inputs=1423-1424 expected=1 actual=1.12 expected_pts=663.664000-664.624000 actual_pts=663.685333-664.785333
2021/01/13 18:49:52.445576 [ENC] Segment 677 has unexpected duration: inputs=1449-1450 expected=1 actual=1.12 expected_pts=676.784000-677.744000 actual_pts=676.805333-677.905333
2021/01/13 18:49:55.645549 [ENC] Segment 680 has unexpected duration: inputs=1455-1456 expected=1 actual=1.12 expected_pts=679.824000-680.784000 actual_pts=679.845333-680.945333
2021/01/13 18:50:07.150793 [ENC] Segment 692 has unexpected duration: inputs=1479-1480 expected=1.08 actual=1.16 expected_pts=691.304000-692.344000 actual_pts=691.325333-692.465333
2021/01/13 18:50:17.552387 [ENC] Segment 702 has unexpected duration: inputs=1499-1501 expected=1.08 actual=1.22 expected_pts=701.664000-702.704000 actual_pts=701.665333-702.865333
2021/01/13 18:50:20.141976 [ENC] Segment 705 has unexpected duration: inputs=1506-1507 expected=1.12 actual=1.22 expected_pts=704.224000-705.304000 actual_pts=704.245333-705.445333
2021/01/13 18:50:27.742989 [ENC] Segment 712 has unexpected duration: inputs=1521-1522 expected=1.08 actual=1.2 expected_pts=711.864000-712.904000 actual_pts=711.885333-713.065333
2021/01/13 18:50:34.943243 [ENC] Segment 720 has unexpected duration: inputs=1537-1538 expected=1 actual=1.08 expected_pts=719.504000-720.464000 actual_pts=719.525333-720.585333
2021/01/13 18:50:36.949931 [ENC] Segment 722 has unexpected duration: inputs=1541-1542 expected=1 actual=1.08 expected_pts=721.264000-722.224000 actual_pts=721.285333-722.345333
2021/01/13 18:50:40.455205 [ENC] Segment 725 has unexpected duration: inputs=1547-1548 expected=1.04 actual=1.12 expected_pts=724.304000-725.304000 actual_pts=724.365333-725.465333
2021/01/13 18:50:43.741539 [ENC] Segment 728 has unexpected duration: inputs=1555-1556 expected=1.08 actual=1.16 expected_pts=727.864000-728.904000 actual_pts=727.885333-729.025333
2021/01/13 18:50:50.343143 [ENC] Segment 735 has unexpected duration: inputs=1569-1570 expected=1 actual=1.12 expected_pts=734.624000-735.584000 actual_pts=734.645333-735.745333
2021/01/13 18:50:54.672714 [ENC] Segment 739 has unexpected duration: inputs=1577-1578 expected=1.08 actual=1.2 expected_pts=738.184000-739.224000 actual_pts=738.205333-739.385333
2021/01/13 18:50:57.749323 [ENC] Segment 742 has unexpected duration: inputs=1585-1586 expected=1 actual=1.12 expected_pts=741.944000-742.904000 actual_pts=741.965333-743.065333
2021/01/13 18:51:07.744936 [ENC] Segment 753 has unexpected duration: inputs=1607-1608 expected=1 actual=1.12 expected_pts=752.184000-753.144000 actual_pts=752.205333-753.305333
2021/01/13 18:51:21.242732 [ENC] Segment 766 has unexpected duration: inputs=1635-1636 expected=1 actual=1.12 expected_pts=765.704000-766.664000 actual_pts=765.725333-766.825333
2021/01/13 18:51:34.946185 [ENC] Segment 780 has unexpected duration: inputs=1666-1667 expected=1 actual=1.12 expected_pts=779.184000-780.144000 actual_pts=779.205333-780.305333
2021/01/13 18:51:41.350042 [ENC] Segment 786 has unexpected duration: inputs=1680-1682 expected=1 actual=1.18 expected_pts=786.024000-786.984000 actual_pts=785.985333-787.145333
2021/01/13 18:51:42.839280 [ENC] Segment 788 has unexpected duration: inputs=1685-1686 expected=1 actual=1.12 expected_pts=787.584000-788.544000 actual_pts=787.605333-788.705333
2021/01/13 18:51:45.561669 [ENC] Segment 790 has unexpected duration: inputs=1689-1690 expected=1.12 actual=1.22 expected_pts=789.224000-790.304000 actual_pts=789.245333-790.445333
2021/01/13 18:51:48.337316 [ENC] Segment 793 has unexpected duration: inputs=1699-1700 expected=1.08 actual=1.2 expected_pts=793.104000-794.144000 actual_pts=793.125333-794.305333
2021/01/13 18:51:50.141321 [ENC] Segment 795 has unexpected duration: inputs=1703-1704 expected=1 actual=1.12 expected_pts=794.664000-795.624000 actual_pts=794.685333-795.785333
2021/01/13 18:51:59.044071 [ENC] Segment 804 has unexpected duration: inputs=1721-1722 expected=1 actual=1.12 expected_pts=803.504000-804.464000 actual_pts=803.525333-804.625333
2021/01/13 18:52:01.051099 [ENC] Segment 806 has unexpected duration: inputs=1725-1726 expected=1 actual=1.12 expected_pts=805.344000-806.304000 actual_pts=805.365333-806.465333
2021/01/13 18:52:09.540097 [ENC] Segment 814 has unexpected duration: inputs=1743-1744 expected=1 actual=1.08 expected_pts=813.824000-814.784000 actual_pts=813.845333-814.905333
2021/01/13 18:52:16.741910 [ENC] Segment 821 has unexpected duration: inputs=1757-1758 expected=1.04 actual=1.12 expected_pts=820.944000-821.944000 actual_pts=821.005333-822.105333
2021/01/13 18:52:20.171227 [ENC] Segment 824 has unexpected duration: inputs=1763-1764 expected=1 actual=1.12 expected_pts=824.144000-825.104000 actual_pts=824.165333-825.265333
2021/01/13 18:52:21.340358 [ENC] Segment 826 has unexpected duration: inputs=1767-1768 expected=1 actual=1.12 expected_pts=825.504000-826.464000 actual_pts=825.525333-826.625333
2021/01/13 18:52:23.237416 [ENC] Segment 828 has unexpected duration: inputs=1771-1772 expected=1 actual=1.12 expected_pts=827.624000-828.584000 actual_pts=827.645333-828.745333
2021/01/13 18:52:28.441085 [ENC] Segment 833 has unexpected duration: inputs=1781-1782 expected=1 actual=1.12 expected_pts=832.064000-833.024000 actual_pts=832.085333-833.185333
2021/01/13 18:52:33.341091 [ENC] Segment 838 has unexpected duration: inputs=1793-1794 expected=1 actual=1.12 expected_pts=837.184000-838.144000 actual_pts=837.205333-838.305333
2021/01/13 18:52:43.837925 [ENC] Segment 848 has unexpected duration: inputs=1815-1816 expected=1 actual=1.12 expected_pts=848.104000-849.064000 actual_pts=848.125333-849.225333
2021/01/13 18:52:47.762116 [ENC] Segment 852 has unexpected duration: inputs=1823-1824 expected=1 actual=1.08 expected_pts=851.984000-852.944000 actual_pts=852.005333-853.065333
2021/01/13 18:52:55.040081 [ENC] Segment 860 has unexpected duration: inputs=1839-1840 expected=1.12 actual=1.22 expected_pts=859.224000-860.304000 actual_pts=859.245333-860.445333
2021/01/13 18:53:14.337637 [ENC] Segment 879 has unexpected duration: inputs=1880-1881 expected=0.96 actual=1.04 expected_pts=878.664000-879.584000 actual_pts=878.725333-879.745333
2021/01/13 18:53:19.434904 [ENC] Segment 884 has unexpected duration: inputs=1890-1891 expected=1 actual=1.12 expected_pts=883.664000-884.624000 actual_pts=883.685333-884.785333
2021/01/13 18:53:24.063802 [ENC] Segment 889 has unexpected duration: inputs=1900-1901 expected=1.08 actual=1.2 expected_pts=888.304000-889.344000 actual_pts=888.325333-889.505333
2021/01/13 18:53:37.485045 http: TLS handshake error from IP (hidden) : EOF
2021/01/13 18:53:37.738894 [ENC] Segment 902 has unexpected duration: inputs=1928-1929 expected=1 actual=1.12 expected_pts=901.584000-902.544000 actual_pts=901.605333-902.705333
2021/01/13 18:53:41.685878 [HLS] Stopping transcoder session ch33-dANY-7808913a504c (out: 15m8.024011s, finished: false)
2021/01/13 18:53:41.737582 [ENC] Stopped encoder for ch33 in /Volumes/VideoLibrary/DVR/Streaming/ch33-dANY-7808913a504c-309292862/encoder-1-487582207 after encoding 1 to 906
2021/01/13 18:53:41.738120 [TNR] Closed connection to 1252EEF9/0 for ch33 SBS Food
