Most of the time when I try to use the "Up Next" thumbnails on my NVidia Shield Tube, or just try to get to the Library, I will see the yellow exclamation point with a "DVR Not Available" message, which is silly because both the Shield and my desktop which hosts the DVR are hardwired on the same network. If I press the "back" button once after the message comes up, everything works fine.
It seems like the only time this doesn't happen is immediately after I've rebooted the Shield. Any ideas?
Submitted logs under 86c52619-8732-47c8-aaf8-b7b8f8c635f2
