Upgraded to beta and can not stream channels
I long pressed the update button and got the most recent build. Since then I cant play certain channels. Here is the excerpt from the log. Is it possible to downgrade to the stable release so I dont get bobbit-ed by my wife for dropping hallmark???
2019/12/30 21:27:35.057182 [TNR] Opened connection to TVE-Spectrum for ch6090 HALLMARK
2019/12/30 21:27:35.058873 [HLS] Starting transcoder for channel 6090 from 184.59.12.142 (encoder=remux, resolution=1080, deinterlacer=linear, bitrate=10000)
2019/12/30 21:27:35.311984 [HLS] ffmpeg: ch6090-dANY-d43efe8a6fa2: [mpegts @ 0x2ae8080] Could not find codec parameters for stream 1 (Audio: aac ([15][0][0][0] / 0x000F), 0 channels): unspecified sample format
2019/12/30 21:27:35.312029 [HLS] ffmpeg: ch6090-dANY-d43efe8a6fa2: Consider increasing the value for the 'analyzeduration' and 'probesize' options
2019/12/30 21:27:35.313313 [HLS] ffmpeg: ch6090-dANY-d43efe8a6fa2: [hls @ 0x2b04740] sample rate not set
2019/12/30 21:27:35.313333 [HLS] ffmpeg: ch6090-dANY-d43efe8a6fa2: Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
2019/12/30 21:27:35.313344 [HLS] ffmpeg: ch6090-dANY-d43efe8a6fa2:
2019/12/30 21:28:06.363755 [HLS] Stopping inactive session ch6090-dANY-d43efe8a6fa2
2019/12/30 21:28:06.363899 [HLS] Stopping transcoder session ch6090-dANY-d43efe8a6fa2 (out: 0s, finished: true)
2019/12/30 21:28:06.376335 [HLS] Couldn't generate stream playlist for ch6090-dANY-d43efe8a6fa2: Stream did not start within 1m0s. Could not find /home/pj/DVR/Streaming/ch6090-dANY-d43efe8a6fa2/stream.m3u8
2019/12/30 21:28:06.377942 [TNR] Closed connection to TVE-Spectrum for ch6090 HALLMARK
2019/12/30 21:28:18.410344 [TNR] Opened connection to TVE-Spectrum for ch6205 FS-RSN-FSNO3
2019/12/30 21:28:18.412938 [HLS] Starting transcoder for channel 6205 from 184.59.12.142 (encoder=remux, resolution=1080, deinterlacer=linear, bitrate=10000)
2019/12/30 21:28:19.144466 [HLS] ffmpeg: ch6205-dANY-d43efe8a6fa2: [mpegts @ 0x2bde080] Could not find codec parameters for stream 1 (Audio: aac ([15][0][0][0] / 0x000F), 0 channels): unspecified sample format
2019/12/30 21:28:19.144510 [HLS] ffmpeg: ch6205-dANY-d43efe8a6fa2: Consider increasing the value for the 'analyzeduration' and 'probesize' options
2019/12/30 21:28:19.145207 [HLS] ffmpeg: ch6205-dANY-d43efe8a6fa2: [hls @ 0x2bfa740] sample rate not set
2019/12/30 21:28:19.145224 [HLS] ffmpeg: ch6205-dANY-d43efe8a6fa2: Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
2019/12/30 21:28:19.145236 [HLS] ffmpeg: ch6205-dANY-d43efe8a6fa2
It should still stream to the Channels app if the setting is on Home Streaming Quality: Original. Is that not working either?
A new build with a fix is being uploaded. Usually takes about 15 minutes.
Nice! Thanks for the quick update.
Just to answer the earlier question. I am away from home with setting set to original. Other settings didnt work either
Ah if you're away from home that makes sense. You will have to wait another 10min and long-press.
Cool. I'll try it out and let you know either way
Both channels working now! You gents rock the house! (And my wife thanks you!)
