I’ve been noticing for the past few weeks it feels like upnp is unreliable. I use Linksys Velop mesh router. It used to work 99% but seems unreliable now. Am I the only one?
UPnP has never been a great protocol. Your best bet is to:
- Disable UPnP (both in your router and within Channels)
- Ensure your IP is stable by setting up a DHCP reservation for your Channels server
- Set up a manual port forward (both within your router settings, as well as within Channels' settings)
Otherwise, inconsistencies will likely persist.
