Yeah got most working using Channels DVR as a tuner but still trying to figure out Contv ... my brain is fried adding channel ID's and renaming the channels... but thanks your example above has helped me a lot .. I did not know how to add the channel numbers.
#EXTINF:-1 channel-id="7"
You can choose your own channel numbers like above in the m3u file. That way you can order the channels any way you want; or you can keep the Channels-DVR numbers. It doesn't matter. I use my own numbers to group channels in the order I like.
No idea about Contv.
Since I had a schedules direct subscription they have SlingTV and Philo lineups so that did it for ConTV and others.. Thanks once again.
Appreciate the thread guys.
I now have Emby integrated with Channels as a provider for Locast, TVE Philo, etc.
I keep finding more and more great features in Channels-DVR, I just wish I liked the UI as well as I like Emby.
I prefer EMBY because of user Profiles but they fall short in comskip support.
Do you care to share the python script and maybe a full set up guide? I'm a long time Emby User interested in giving this a go.
What started as a python script ended up being a full blow program with a back-end database. In order to have Emby identify the channels without having to match each one in Emby, I had to normalize the call signs and I had to split the m3u file into 5 pieces. This is due to not having a single guide provider that could cover all channels. I didn't want to use SchedulesDirect/xTeve. I did want to use the built in providers that Emby provides. Each of the 5 m3u files were loaded into Emby and each assigned a different guide provider. The benefit of all this is there was not additional configuration of Emby needed. I could convert the back-end db to SQLite if you want to try this. PM me and let's discuss. Not trivial so you will need some skills and a good bit of Gin.
Also, I can't tell you what I did was right, but it works. I knew nothing about any of this when I started.
Wow that is a lot I edited the m3u and added the channels and corrected call signs then I simply added an EMBY comcast east coast lineup along with my west coast one and it worked. That way I can easily add and remove channels. First thing I did in Notepad+ is change
#EXTINF:-1 to #EXTINF:-1 channel-id="XXXX" all ... then edited with correct channel.
#EXTINF:-1 channel-id="6007" tvg-logo="https://tmsimg.fancybits.co/assets/s68344_ll_h3_ad.png" tvg-name="CSPAN" group-title="HD",CSPAN
http://mediapc:8089/devices/TVE-Comcast_SSO/channels/6007/hls/master.m3u8?
#EXTINF:-1 channel-id="6008" tvg-logo="https://tmsimg.fancybits.co/assets/s68334_ll_h3_ac.png" tvg-name="CSPAN2" group-title="HD",CSPAN2
http://mediapc:8089/devices/TVE-Comcast_SSO/channels/6008/hls/master.m3u8?
#EXTINF:-1 channel-id="6009" tvg-logo="https://tmsimg.fancybits.co/assets/s68332_ll_h3_ac.png" tvg-name="CSPAN3" group-title="HD",CSPAN3
http://mediapc:8089/devices/TVE-Comcast_SSO/channels/6009/hls/master.m3u8?
#EXTINF:-1 channel-id="6030" tvg-logo="https://tmsimg.fancybits.co/assets/s58646_ll_h3_ac.png" tvg-name="CNNHD" group-title="HD",CNNHD
http://mediapc:8089/devices/TVE-Comcast_SSO/channels/6030/hls/master.m3u8?
#EXTINF:-1 channel-id="6031" tvg-logo="https://tmsimg.fancybits.co/assets/s64549_ll_h3_ab.png" tvg-name="HLNHD" group-title="HD",HLNHD
http://mediapc:8089/devices/TVE-Comcast_SSO/channels/6031/hls/master.m3u8?
I'm in the AZ timezone and the guide times were off on quite a few channels. Your approach would have been a lot easier, but for some reason I had to use a combination of Spectrum, Dish, Direct TV and OTA to get the guide correct for me. I ended up getting rid of the Roku and got a new TV for the pool a few months later so I haven't touched this since.
I made some improvements in the latest pre-release:
- use
channels.m3u?format=tsfor stream.mpg urls - added
channel-id - changed
tvg-nameto use call sign for easier guide matching - removed duplicate channels when using
ANYdevice
You guys are really great thanks for making this easier much appreciated.
This has proven to be better than I thought... By having Channels DVR be the backend I can share tuners between EMBY and other Apps on my test System. I can watch the same Channels on EMBY and Channels DVR and only use 1 tuner... Also from my test systems.
Are you having any problems with channels releasing the HDHR tuner after emby is finished with it.
I recently started using Jellyfin (open source fork of Emby) to hook up a friend out of the area to get local sports channels and that issue with Jellyfin where the tuner still looks like the channel is being watched when it isn't.
No Problem at all they are release right away.
Use format=ts to prevent that issue.
That is what I am using.
Ok thanks. I would like to see channels and emby share the HDHR.
They do, but maybe not in the way you are thinking. Presently, any app can request a stream from the tuner, and if there are free tuners, it will serve the stream to the requesting program. So, both Emby and Channels can request a stream from a Quatro (for example), and that will use 2 of the 4 available tuners.
If what you are asking for is that the tuner stream the same program to both Emby and Channels simultaneously (1 tuner being used to send the same stream to different programs/addresses), that is not possible.
