Using Channels with Emby
I tried using the the Channels as a tuner post to add channels to emby but was unable to get it to work. No matter what I did it would tell me no source found. How to get the m3u and xml data to put into emby? On pc running windows 10. Any help would be great.
Try
http://ip.of.dvr.server:8089/devices/ANY/channels.m3u?format=ts
Guide data
http://ip.of.dvr.server:8089/devices/ANY/guide/xmltv?duration=604800
I tried that from the original post but it kept telling me it was unable to find it. So i put it in the address bar and got error 404. Am i missing something?
I tried both the pc ip and the ip that shows up when i have channels open in the web admin
I don’t know then. I don’t use emby or windows. Try disabling firewall to test.
I have done that. That was the only way i could get channels to work. I do appreciate you trying to help. Ill keep toying woth it and see what happens.
Is Channels running on the same PC as Emby? If so, here are the entries I used which work for me;
Tuner- http://127.0.0.1:8089/devices/ANY/channels.m3u?format=ts&filter=favorites
Guide- http://127.0.0.1:8089/devices/ANY/guide/xmltv?duration=1209600
Yes it is. Sorry for the extremely late response. Time got away frome as well as other daily life things. I finally got it qork. But the stream from plex only lasts about a minute and then cuts off. Trying to get it to work so my s/o can watch akc tv. But it doesnt seem to want to play anything from plex more than a minute. And then fail when i try to reload. I am assuming this is a plex coding issues. As it does it in bith emby and channels.
