Hello,
Loving Channels so far on my Bravia 8 and it's meeting almost all my expectations.
The one small issue I'm having is with how Channels (and my TV) seem to be treating numbers on the remote control.
If I input numbers from the remote on the guide, Channels behaves as I'd expect. I can input any number combination and it will scroll to that channel. However, if I input a number during live TV, Channels begins to change the channel but the built in Android TV apps instantly rip control away and open up instead.
My TV comes with two ways of watching OTA freeview here in the UK (the Youview app and the stock Android TV "TV" app), and if I disable them both, Channels will flawlessly switch channel during live TV when I enter a number. The problem is, disabling the built in TV apps remove major functionality from the TV (can't change input and other built in apps that depend on them cease to function).
Since I'm able to input numbers from the remote on the guide without these other stock apps interfering, is it possible there's some way to fix it so I can also enter numbers during live TV, without these other apps thinking I want to use them? Unfortunately button remappers don't fix the problem, and using numbers on a keyboard also still end with the same result. CH+/CH- and other shortcuts on the remote all work fine and don't switch to another app.
Thanks
