Using Remote DVR with Locast and VPN
I can get the remote DVR to work, and I can get all my channels to work with the exception of the locast channels. They obviously won't work because I had to disable my VPN to get access to my remote DVR, any thoughts on how to get Locast working with my remote DVR with the VPN?
I don't really understand what you mean. Why is there a VPN involved?
Ah, I don't have local channels in my area, so I use Locast to get them from the San Francisco area, which is closest to me for local major networks. Locast requires I use a VPN since I don't live in the service area for Locast.
You could route all traffic over your normal ISP connection and add static routes to route locast traffic over the VPN.
Is this a remote DVR or are you trying to access your local DVR remotely?
