I have 2 Prime cable card tuners. I set up one and hid 308 channels I don't have or are duplicate SD channels. I added another prime and used the same lineup but the hidden channels don't migrate over.
Is there a way to do this?
https://forum.silicondust.com/forum/viewtopic.php?f=125&t=68701
The tool you're looking for is HDHRUtil-Tuner-channelSettingDuplicate. It will copy the favorite/enabled/disabled status from one tuner to another.
I couldn't get it to work in windows. I downloaded and installed python and followed the examples. But it appears to be missing a module called natsort. I tried downloading it but no go, I guess manual is how its getting done.
Thanks
