V2 layout and pinning
Is it possible to have the pins and theme saved universally, no matter which device I access the server from, I would like to have the theme I selected, saved and my pinned settings populate.
Also, when pinning on the left side, is it possible to not have the setting "move" to the pin and rather it create a shortcut in the pinned section? It would be in 2 spots but I feel like it would make sense to just have a shortcut pinned rather than moving the whole section to pinned.
Loving this new layout. Much cleaner overall and so much more friendly to use.
Also, is it possible to move the pins up and down? As I added more I realized that I wanted a couple at the top.
Pins are browser based and will stay that way. This allows more flexibility. Making it server based means only a single set of pins, even if you wanted a set for mobile and a set for desktop.
There's no plans to change any of these.
:heart:
Pins are re-orderable now.
Any chance there could be a link to the server in the iphone/ipad app? It would make it easier to access that way. Not sure if there are downsides to doing this.
Can't seem to move pins around in an Android mobile browser. Tried long press but didn't work.
Also, agree with above poster that pins should really be shortcuts that are renameable. I have a pin to my library that only shows recordings and would love to be able to rename it as Recordings, but it shows as Library because that's what was pinned.
You can’t and won’t ever be able to rename pins. They’re actual sections.
You should just make a preset and pin it, for those Library filters. You can name them anything you want. This is the appropriate way to handle this. Then you can use Library without changing what you expect.
i know you closed this, but some selection names are duplicated, kinda confusing.
Did you name the preset Library?
no, I think I had it pinned before I set any preset. anyway, I see now how to pin the preset so that one is easier, however I still have Library Scanning pinned but it just shows as Library.
Thanks! Got a recordings preset pinned now. Sorry for all the questions about how it all works, hope you have a good Thanksgiving.
