Description of issue: I tried to access the V2 interface and it 404s. I am running 2026.10.24.0621
I expected: I expected it to load.
What actually happened: i'm getting a 404 error and the old interface.
It's missing from the dropdown on V 2026.10.24.0621 as well. Looks like a bad build
Hmmm... I must be lucky (for a change). I'm also on V 2026.10.24.0621. My drop down is there and works as it should. (using Chrome browser on my Chromebook) I'll check my PC and see if it's funky over there.
EDIT / UPDATE: It seems to function correctly on my PC with Chrome browser as well.
You're all on the stable build. V2 is only on pre-release.
Pushing out a pre-release now for ya'll to get back on.
Ah, that makes sense. I didn't realize that was a stable build. I just pulled the latest release. Thank you so much, Jon.
New pre-release is out:
