Can the devs please add Vegas 34 (KMCC) to TVE it is the local streaming channel for the Vegas Golden Knights, thanks in adavnce,,
You need an antenna for it
It actually says that fubo tv is supported.
I don't see a web stream on their site.
Not that. In order for TVE to work, you need a webstream on the actual site.
The only remedy for you to get the stream in channels is the fubo bridge, or use an antenna with a HDHR or Tablo or use your provider's app with CC4C or HDMI/ah4c
Ok thank you for the clarification. Admin you can close this post thanks.
