2019/11/30 08:31:07 [SYS] Starting Channels DVR v2019.11.19.2312 (linux-x86_64 pid:1) in /channels-dvr/data
2019/11/30 08:31:07 [HDR] Found 0 devices
2019/11/30 08:31:07 [ERR] Failed to refresh auth: missing oauth client
2019/11/30 08:31:07 [SYS] Started HTTP Server
2019/11/30 08:31:07 [SYS] Bonjour service running for dvr-ryzen.local. [192.168.1.7]
2019/11/30 08:31:27 [DVR] Recording engine started in /shares/DVR
2019/11/30 08:31:27 [SYS] Created database snapshot: backup-20191130.083127
2019/11/30 08:31:53 [TVE] Auth starting for Verizon as [email protected]
2019/11/30 08:31:53 [TVE] action=auth mvpd=Verizon requestor=nbcentertainment
Running Docker Channels DVR:TVE
Upgrade first by click-and-hold on the Check For Update button
Is the system clock correct?
I see you have Timezone set to UTC.
Also version 2019.11.19.2312 may not be the latest pre-release version.
I did the click and hold thing no change
and I can't set the Time Zone. It's set to UTC in docker container
Is the docker container up to date?
Is this running on a residential network?
Can you connect to the container and run:
chromium --version
You can use the -e TZ=... option for docker run command (i.e. docker run -e TZ=America/Los_Angeles ...).
If you use docker compose, you may want to see https://stackoverflow.com/questions/39172652/using-docker-compose-to-set-containers-timezones .
Can’t bash into the container. Says bash is not in the $PATH.
And I did click and hold to see if there was an update available there was not
Added TZ still shows UTC
docker run -it /bin/sh
It tried to Pull the regular image but I use the TVE image
Something is the matter with the docker install. Moved to local install works fine. Please close this thread at your leisure.
