Hello all.
I have been a long time lurker just reading up on as much as possible.
We just disconnected our DirecTV and installed an Antop 400BV. I used tvfool and antenna web to guide us on what to buy. Currently using a homerunHD quatro and Apple TVs.
The Antenna is currently mounted about 12ft up and pointed to the towers. And I receive about 40+ channels. They come through super clear with one exception....
CW network.
WPIX in New York City is located in the same direction as the other stations, but I can hardly pick it up. It is a high VHF channel which is only 35 miles away (all the other stations are the same distance/location) what can I do to receive this channel? Should I move the antenna up to my roof (30ft off the ground) or should I consider and FM trap?
