Hi folks, it's easy to adjust audio delay. But there are no options to adjust video delay. It would be great if we could adjust video to be delayed a few MS for those of us watching via Bluetooth headsets that don't support low-latency codec options (almost all Bluetooth audio). It would be even greater if there was a quick way to enable/disable this feature for when we switch from Bluetooth headset to normal speakers.
Bump. If it helps, Kodi has a feature to delay video.
To delay video in Kodi:
- Open Kodi and start playing a video.
- While the video is playing, bring up the on-screen display.
- Select the settings (gear icon) and go to
Audio and Subtitle Settings. - Adjust the
Video calibrationsettings to delay the video.
