View CCTV on Channels?
I have Blue Iris running with 6 cams.
Is there a way to view these cams on Channels? It would be handy sometimes to flick over to CCTV cam during an ad break for example.
If so, is there a guide for this?
Thanks.
Search for "RTSP" and you will have your answer and troubleshooting.
Using the Custom Channels feature, you can add your own channels to your guide using live streaming sources.
